May 8, 2025 8:26 PM UTC
Command to run WCA
Version: Windchill 13.0
Use Case: What is the command to run the wca? i've been looking and can't figure it out
Description:
Need to run Windchill confiugration assistant but can't figure out how.
avillanueva
23-Emerald II
May 8, 2025 8:38 PM UTC
Stop Windchill
Under windchill shell navigate to <Windchill>/utilities/wca/
Generate file windchillconfigurator.xconf
Run command ant -f WindchillConfigAssistant.xml configureWindchill
Will generate <Windchill>\utilities\wca\conf\windchill\windchillconfigurator.xconf, which includes properties WCA calculated
https://www.ptc.com/en/support/article/CS153338?source=search#WCA
avillanueva
23-Emerald II
Stop Windchill
