Jan 28, 2026 8:17 AM UTC
Commercial Library
I'm looking for a 3D commercial library already integrated with windchill partlink. I means somthing already made from third part software PTC certified that can by from the market
18-Opal
Jan 28, 2026 8:27 AM UTC
Hi @Beniamino71,
Could you clarify what you mean by a 3D commercial library?
Are you referring to standard components, or product-specific models?
Jan 28, 2026 8:53 AM UTC
I refer to standard commercial component as:
Screws
Bearings
electric motors
gearboxes
pneumatic couplings
pneumatic cylinders
Classified for brand end mechanical characteristic
I look for e third-part product certify PTC working on Partslink classification that allow quickly find 3d model to use in Creo Parametrics
B.
18-Opal
Jan 28, 2026 9:00 AM UTC
There are multiple vendors that provide 3D models compatible with Windchill and Creo.
I am not certain which vendors are officially certified by PTC.
It would be best to check directly with PTC for confirmation.
avillanueva
23-Emerald II
Jan 28, 2026 3:38 PM UTC
@TDT had a good suggestion. Integrating with PartsLink is a tall ask since every one would have this implemented differently. Attribute names, definitions, structure is up to the end customer. There is not one classification for all but likely very similar. Suggested to the Windchill AI Part Classification team that there is opportunity to "suggest" classification based on data they may see from users.
18-Opal
Jan 28, 2026 4:38 PM UTC
I would suggest that if someone is planning to implement PartsLink, the following URL may be helpful.
https://partsolutions.com/partsolutions/standard-parts-engineering-reuse/
