Jan 11, 2024 9:32 PM UTC
comp slash folderbrowser_table
Seeing this:
are these exceptions related?
[ajp-nio-127.0.0.1-8011-exec-7] Id=4eihs1v9;lr9djznj;5681;1wipac;6564, RequestURI=/Windchill/ptc1/comp/wt.pdmlink.PDMLinkProduct.infoPage, QueryString=ContainerOid=OR%3Awt.pdmlink.PDMLinkProduct%3A217906851&oid=OR%3Awt.pdmlink.PDMLinkProduct%3A217906851&u8=1&portlet=component, StatusCode=501, ElapsedSeconds=0.038191472
[ajp-nio-127.0.0.1-8011-exec-7] com.ptc.mvc.controllers.ExceptionController - message : Could not initialize class com.ptc.core.rule.server.delegate.init.RuleConfigurableTypeAttribute error:-------------org.springframework.web.util.NestedServletException: Handler dispatch failed; nested exception is java.lang.NoClassDefFoundError: Could not initialize class com.ptc.core.rule.server.delegate.init.RuleConfigurableTypeAttribute - org.springframework.web.util.NestedServletException
[ajp-nio-127.0.0.1-8011-exec-7] com.ptc.core.components.beans.DataUtilityBean - CaughtException while processing column: displayIdentifier. Enable 'com.ptc.core.components.beans.DataUtilityBean' logger for full stack trace.Could not initialize class com.ptc.core.rule.server.delegate.init.RuleConfigurableTypeAttribute
rleirAnswer
Jan 16, 2024 8:42 PM UTC
Thanks for this URL.
The QA machine has less memory. It filled its swap, then we rebooted. d'oh
avillanueva
23-Emerald II
Jan 12, 2024 12:02 PM UTC
Is this related?
https://www.ptc.com/en/support/article/CS356298?source=search
See close to the error you are seeing.
rleir17-PeridotAuthorAnswer
HelesicPetr
Jan 17, 2024 8:10 AM UTC
Hi @rleir
Same thing happens if an user does not work in the browser for more then 30 minutes.
Usually there is auto-logout(there is timeout)and system needs to reauthenticate the user.
So full page refresh is needed.
If user uses F5 then everything is and error is not shown again.
I've seen it on many places of the system. Folder, Advanced search, Structure, wizards.
PetrH
