Jun 5, 2026 1:45 AM UTC
Compatibility and Integration between Windchill and ZW3D: Looking for User Experiences
Hello everyone,
Our team is currently evaluating the integration of ZW3D with PTC Windchill as our PLM system. Before moving forward, we would like to ask the community about the compatibility, integration feasibility, and overall user experience regarding this setup.
Specifically, we are curious about the following:
  1. Integration Without WGM: Is there a way to connect and use ZW3D directly with Windchill without utilizing the Workgroup Manager (WGM)? If so, what are the available methods (e.g., using specific APIs or third-party connectors) and what are their limitations?
  2. Workgroup Manager (WGM) Integration: Is there a dedicated Workgroup Manager or a reliable multi-CAD gateway officially available for ZW3D to connect seamlessly with Windchill? How stable is the data management (Check-in, Check-out, and revision control) for ZW3D files through WGM?
  3. Data and Attribute Mapping: Does the system accurately map CAD attributes and metadata between ZW3D and Windchill? Are there any known issues with BOM (Bill of Materials) generation or drawing links?
  4. User Experience and Bottlenecks: For those who are currently using or have previously implemented this combination, have you encountered any major inconveniences, performance drops, or workflow limitations in daily operations?
Any insights, use cases, or advice on potential pitfalls would be greatly appreciated.
Thank you in advance!
HelesicPetr
Jun 16, 2026 6:56 AM UTC
Hi ​@JA_13802817
Try to contact the company that have an experience with that integration
https://www.amcbridge.com/
Developing own integration is always time consuming activity.
PetrH
HelesicPetr
Hi ​@JA_13802817
PetrH
