3-Newcomer
Nov 27, 2024 7:52 AM UTC
Component classification attribute
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
The component classification attribute setting allows multiple values ​​and no duplicate values, which is invalid, and duplicate values ​​will still exist.
Translated by the moderation using Google Translate
部件分类属性设置允许多值且无重复值后无效,仍会存在重复值
Catalina
Community Manager
Nov 27, 2024 8:00 AM UTC
Hi @JS_10230450
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please consider adding screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
Fadel
23-Emerald II
can you add some screensots to undestand ?
Buiꓘa
3-Newcomer
Nov 27, 2024 9:12 AM UTC
With the property set this way, setting duplicate values ​​during editing can still be saved and checked in
属性这样设置后,编辑时设置重复值仍然可以保存检入
Nov 27, 2024 8:14 AM UTC
I think I have encountered this.
When you have the same attribute (internal name) in two different nodes of the classification tree, then if you do a multiple classification of the part with these 2 nodes assigned, then the attribute that is same is shown as only one time and system treats it as duplicate.
This is how PartsLink behave and it is "Working to Spec".
Perhaps my friend Fadel can check from PTC support side.
Cheers
Hari
