Nov 30, 2016 6:37 PM UTC
Conditional routing based on Document attributes
Hello all,
I am trying to have a conditional routing in a workflow, based on a specific attribute of the routed document.
In the expression I use this:
//get the attributes of the document.
wt.iba.value.IBAHolder holder = wt.iba.value.service.IBAValueHelper.service.refreshAttributeContainerWithoutConstraints(doc);
wt.iba.value.DefaultAttributeContainer ac = (wt.iba.value.DefaultAttributeContainer) holder.getAttributeContainer();
if (ac != null) {
wt.iba.value.litevalue.AbstractValueView[] avalues = ac.getAttributeValues();
for (int i=0;i<avalues.length;i++) {
wt.iba.value.litevalue.AbstractValueView val = avalues[i];
if (val.getDefinition().getName().equals("contracttype")) IPselect= val.getLocalizedDisplayString();
break;
}catch(Exception e) { System.out.println("Caught Exception:" + e.toString()); }
Then in the OR I have put this:
result="IP_Yes";
if (IPselect.equalsIgnoreCase("Consulting")) result="IP_No";
if (IPselect.equalsIgnoreCase("Service Agreement")) result="IP_No";
The problem I have is that some times it gets the value from the document (thus "IPselect" has a value in the workflow) and some others not.
Any ideas?
Thank you in advance
John
Dec 1, 2016 7:45 AM UTC
It is solved. I found the error.
Originally I was telling to check this:
                break;
So the if was break at the first attribute it was getting (any attribute). Obvisously it was not the one i wanted. So I have put the break inside like that:
                if (val.getDefinition().getName().equals("contracttype")) {
                break;
So now it will check all the attributes, and it will stop when it will get the "contracttype".
Regards
John
Dec 1, 2016 6:52 AM UTC
Thank you for your comment.
The problem is that when the process run, sometimes I get the value of the attribute and sometimes not.
Regards
John
ipsomiadis1-VisitorAuthorAnswer
                break;
                break;
Regards
John
22-Sapphire I
Dec 1, 2016 3:50 PM UTC
Good for:
- keeping all brain cells really busy and working hard
- keeping us all humble
How good you feel when you find the problem seems to be in proportion to how hard it is to find the problem.
BenPerry
Dec 29, 2016 11:38 PM UTC
Ioannis Psomiadis‌,
You may want to consider switching over from wt.iba.value.IBAHolder to com.ptc.core.lwc.server.PersistableAdapter.  I think your code is being deprecated.  And the new code is fewer lines.  Check it out in the context of the other posting:  Re: PBO Attribute captured in a workflow‌
doc = (wt.doc.WTDocument)primaryBusinessObject;  // you can skip this - you already instantiated "doc"
com.ptc.core.lwc.server.PersistableAdapter obj = new com.ptc.core.lwc.server.PersistableAdapter(doc,null,null,null);
obj.load("contracttype");
IPselect = (String)obj.get("contracttype");
Jan 4, 2017 3:35 PM UTC
Happy New Year Ben,
Thank you for your tip. I will test it in our development environment and I will let you know.
Regards
John
