Aug 7, 2023 3:42 PM UTC
configurable reference link is hidden by the OOTB validator
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.10
while creating a new configurable reference link as per the help center steps [Customizing Configurable Link Tables] the newly created link is hidden by the OOTB validator
Here are the errors that I faced
HelesicPetr
Aug 8, 2023 11:23 AM UTC
Hi @MN_10720981
remove the filters (validators) from the customAction.xml configuration. or there where the tables are defined.
PetrH
HelesicPetr
Aug 8, 2023 6:11 AM UTC
Hi @MN_10720981
What is the question?
For configurable links you need to create own page tab with own table to show the links.
PetrH
Aug 8, 2023 11:19 AM UTC
Hi Team,
A new tab has been created for the configurable link but the links are always hidden:
Kind Regards,
Madhuri Nanaware
HelesicPetr
Hi @MN_10720981
PetrH
Aug 8, 2023 10:41 AM UTC
@MN_10720981.. Check if following property was set ..
xconfmanager -p -s "com.ptc.windchill.enterprise.part.showReferenceLinksTable=ALL" -t codebase\wt.properties
