Apr 3, 2023 8:11 AM UTC
Configuration of CAD worker
Hi @BenLoosli
  1. Can I create multiple CAD workers on remote machine, if i created 4 Creo CAD workers, does it need 4 creo view adapters?
  2. are these 4 Creo workers are identical folders?
  3. One creo parametric application works with these 4 CAD workers? I mean one CAD application is enough for working with multiple workers?
avillanueva
23-Emerald II
Apr 4, 2023 11:24 AM UTC
A Creo View adapter is the code to convert a certain type of CAD or doc data to a format that Creo View and Windchill understand. There is an adapter for all the major CAD applications, Office, ECAD vendors, STEP, PDF, etc. Each type you want to publish needs its own adapter. From that, you can create any number of workers to scale. A worker is configured to use the specific adapter to publish data on command from the server.
Think of it like people in a company, Each department processes different tasks. The workers are like employees in that department. If more jobs are coming into a certain department, you can scale up the number of employees to meet the demand.
HelesicPetr
Apr 3, 2023 8:28 AM UTC
Hello @SModugu
1.. Yes you can create multiple workers
2. Each worker needs own folder setup
3. One Creo application is enough for this setup.
Also one license is consumed for all creo instances
Following article can help you CS29308
Following community discussion can also help
https://community.ptc.com/t5/Windchill/Multiple-CAD-Workers-on-a-Single-Remote-PC/m-p/841796#M69263
PetrH
SModugu13-AquamarineAuthor
Apr 3, 2023 8:33 AM UTC
1. if i configured 4 creoworkers, does it need 4 Creo view adapters?
2. all these should be copy and paste of one worker folder and rename it?
3. for 1 creo application, how many workers can be setup as above point 2?
HelesicPetr
Apr 3, 2023 8:37 AM UTC
1 what do you mean 4 Creo view Adapters?
     just one application is installed and a setup folder is created for each worker. (setup1 , setup2 setup3 atc)
2. I would not use copy paste because you need to define alias for each worker. All is described in the article.
3 As many you have resources. For one customer I setup 15 workers with one creo aplication
Do not forget to create enough new publish queues.
PetrH
