Feb 11, 2015 8:08 PM UTC
Configuration of PDF OCR with Adobe Livecycle Server ES3
We have scanned documents that are not searchable, so we would like to use OCR functionality to create viewables using Adobe Livecycle Server. When enabling the OCR capability we receive an error and it is unclear what the cause is. Any one having experience with configuration of OCR based on Adobe Livecycle Server (ES3)?
Apr 16, 2025 10:03 AM UTC
This would be very valuable to have and would make AEM/PDF Publisher a worthwhile investment.
Apr 16, 2025 5:04 PM UTC
If you are a bit handy(or search areound a bit) you can use Python to extract images from pdf files.
With PyTesseract (and Tesseract) you can do the OCR your self and merge the different files again to pdf.
Apr 17, 2025 7:25 AM UTC
These things are all trivial in isolation. Doing it as part of Windchill publish workflow is another issue however.
PTC explicitly support use of AEM, which happens to have OCR out of the box. PTC does not support customisations and extensions, and provides very little documentation on how to modify the publication generation steps like that.
Fortunately, Chromium has Pdf-Searchify which uses Tesseract to generate in-browser OCRing of PDF images- but this doesn't result in index-able data for SOLR Server.or Windchill Search Preview.
