6-Contributor
Jul 8, 2021 6:28 AM UTC
Configuration to enable different object types to be displayed in PSB
Currently only few object types are enabled (to be displayed/filtered) in the PSB.
It would be good to enhance this feature to display other types (i.e., configurable links, different types of parts, docs etc..)
avillanueva
23-Emerald II
Jul 17, 2021 5:34 PM UTC
Perfect suggestion for Windchill Ideas but short of that, can you use the table views/filters to give what you want? Assuming the links are bases of the main part, doc, caddoc objects, you might be able to show all but filter out ones you do not want.  Filter by object type.
