ShirishMorkhade
Jun 5, 2015 6:18 PM UTC
Configure Auto Suggest Picker (SuggestTextBox) on object creation page?
Hi All,
I am trying to implement Auto Suggest picker (SuggestTextBox) on WTDocument/WTPart creation wizard in Windchill 10.1. Does anybody have done this before?
Can anyone please help me on this?
Appreciate your help.
Shirish
2-Explorer
Jun 10, 2015 4:24 AM UTC
I think we did something similar in one of our projects. We created a custom wizard to add additional data input fields.
if you want to auto fill user,organization or context, I remember we have it OOTB. But for custom  objects, you will have to create a suggestion class (implementing Suggestable interface) which would basically do the query. This class should be registered as a service, This service could be called from suggestTextBox wrapper tag.
Binesh
Barry Wehmiller International
2-Explorer
Binesh
ShirishMorkhade
Jun 10, 2015 1:27 PM UTC
Hi Binesh,
Yes, you're correct. I followed same approach (create a Suggestion class which implements Suggestable Interface).
I am able to make IBA text field to behave like a suggestible; however when I type something in the field it spins for a while and nothing is returned as suggestions.
In the MS logs below exception is logged:
ERROR : com.ptc.mvc.controllers.ExceptionController  - message : An unexpected error has occurred.  Contact your system administrator for assistance.
error:-------------java.lang.NullPointerException
        at com.ptc.core.components.suggest.SuggestableFactory.getSuggestions(SuggestableFactory.java:75)
        at com.ptc.jca.mvc.controllers.SuggestController.processRequest(SuggestController.java:96)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:176)
        at org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.invokeHandlerMethod(AnnotationMethodHandlerAdapter.java:436)
        at org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.handle(AnnotationMethodHandlerAdapter.java:424)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:669)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:574)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
        at com.ptc.jws.servlet.filter.WsdlServletFilter.doFilter(WsdlServletFilter.java:61)
In the UI it is behaving like this:
Note sure if I am missing something. I can share step-by-step instructions I followed to implement this feature.
Shirish
Aug 18, 2015 4:38 PM UTC
Hello Shirsh,
Can you please share your instructions?
I rencetly worked on auto suggest and it is working for me.
One thing I need to figure out is how to add a button to the Auto Suggest field and seen in the screenshot you posted.
Thank you,
Chaitanya A. Jagdale
