7-Bedrock
configure publishing based on a specific Lifecycle State
Hello Team,
We would like to seek your support regarding the following customer requirement.
Customer Requirement – Lifecycle State-Based Publishing:
The customer wants to configure publishing based on a specific Lifecycle State. Currently, publishing is occurring for all Lifecycle States, but the customer requires publishing only when the object reaches the “Released” state.
The requirement is applicable to both:
  • EPM CAD Documents (Creo, Inventor, SolidWorks)
  • WT Documents (Office documents)
Could you please confirm whether it is possible to configure Windchill to publish only objects in the “Released” Lifecycle State and prevent publishing for other states?
The customer is using Windchill 12.1.2.7
If this configuration is supported, could you please share the relevant PTC Article / Please provide the steps
Any guidance or recommendations would be greatly appreciated.
Thank you in advance for your support.
    18-Opal
    Hi ​@KR_1012184030,
    You need to use the publish rules.
    Please refer to the following article.
    https://www.ptc.com/en/support/article/CS365574?source=search
    Check whether you already have any publish rule configuration set up. If so, modify the file accordingly.
