6-Contributor
Nov 17, 2025 5:42 AM UTC
Configure Windchill SSO with shibboleth, stuck with the 'target' url
As configure Windchill SSO by following the manual: Security Assertion Markup Language (SAML) Authentication , now we are able to open the SSO login page and login with username/password successfully. But when the browser tries to jump into Windchill home page, it showes error message like 'Failed to process the request, Contact your administrator...'. As checked the method server log, there're debug message like below:
2025-11-17 13:09:14,115 DEBUG [ajp-nio-127.0.0.1-8011-exec-1] sso.shibboleth.sessionHook wcadmin - Query Parameter - return = https://plmdev.xxxx.com:4443/Shibboleth.sso/SAML2/POST?hook=1
2025-11-17 13:09:14,115 DEBUG [ajp-nio-127.0.0.1-8011-exec-1] sso.shibboleth.sessionHook wcadmin - Query Parameter - target = null
2025-11-17 13:09:14,116 DEBUG [ajp-nio-127.0.0.1-8011-exec-1] sso.shibboleth.sessionHook wcadmin - Windchill Domain Name = plmdev.xxxx.com
Just wondering where we can set the 'target' properly so that the sessionHook can handle the request successfully. Any advice will be appreciated...
shlcm6-ContributorAuthor
6-Contributor
Nov 17, 2025 5:47 AM UTC
avillanueva
23-Emerald II
Nov 17, 2025 12:41 PM UTC
out of curiousity, was wcadmin using basic authentication? You mentioned that you have it working with both SSO and username/password. I am wondering if its crossing over which would suggest a webserver misconfiguration.
6-Contributor
Nov 18, 2025 1:29 AM UTC
Thanks for the response. No basic authentication now. Now we login using SSO's login page and username/password are also provided by SSO team. What do you mean webserver misconfiguration, we configured Apache following the official document that mentioned in the original post.
Emeritus
Nov 28, 2025 4:37 AM UTC
Hello @shlcm,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
