3-Newcomer
Feb 15, 2024 8:30 AM UTC
contradictory conditions in publish rules
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.8
Is it possible to have contradictory conditions in publish rules.
We want to have a condtion in the publish where content (STEP/PDF) only is published when attribute MODEL_TYPE is empty. If this value is not empy it should not publish any content only the pvz.
HelesicPetr
Feb 15, 2024 12:58 PM UTC
Hi @Hans_TS
But you use regex definition in the value definition.
Iam sure that it can not work.
use <or> definition for each value or use regex= parameter instead of value=
PetrH
Hans_TS3-NewcomerAuthor
3-Newcomer
Feb 15, 2024 8:32 AM UTC
We already tried the following:
<condition name="3DPRT_released">
<and>
<attribute name="epmdoc_docType" value="CAD Part" />
<attribute name="epmdoc_MODEL_TYPE" regex=")$" />
<or>
<attribute name="epmdoc_lifeCycleState" value="Design Review" />
<attribute name="epmdoc_lifeCycleState" value="Design Approved" />
<attribute name="epmdoc_lifeCycleState" value="Design Manual Approved" />
<attribute name="epmdoc_lifeCycleState" value="Prototype" />
<attribute name="epmdoc_lifeCycleState" value="Production" />
<attribute name="epmdoc_lifeCycleState" value="Obsolete" />
</or>
</and>
</condition>
Publish rule has no error but when attribute MODEL_TYPE is empty is not publishing any content
HelesicPetr
Feb 15, 2024 9:07 AM UTC
Hi @Hans_TS
Empty? so try value=""
PetrH
3-Newcomer
Feb 15, 2024 9:10 AM UTC
Thank you for your response.
We already tried that but this is not working.
This is resulting in an error during replacing the publish_rules.xml.
H.smits
