Apr 4, 2025 3:45 PM UTC
Control characteristic number not reflect in ESI XML under the StandardControlCharacteristicUsage
I am using Windchill Enterprise Systems Integration Release 11.1 and Datecode with CPS M020-CPS22
StandardControlCharacteristicUsageResourceLink
Is not mapping the name of control characteristics number as the tool resource is linked with the control characteristics
Here are the errors that I faced
Control Characteristic number is not getting mappes to the processing resource allocated to it in the ESI XML.
Catalina
Community Manager
Apr 29, 2025 2:53 PM UTC
Hi @HD_10841985
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Can you provide more details or a screenshot of the error message when the control characteristic number is not mapped?
  • How is the mapping currently configured in the ESI XML? Are there specific fields or tags that should be linked but are not?
  • Are certain processing resources more affected by this issue than others? If so, which resources are consistently problematic?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
