6-Contributor
Apr 23, 2025 2:49 PM UTC
Converting one subtype of EPMDocument from another subtype of EPMDocument
I want to convert the current type of object which is a EPMDocument subtype to another subtype of EPMDocument. Will it be possible using wt.epm.util.SoftTypeChangeUtility ?
avillanueva
23-Emerald II
Apr 23, 2025 3:19 PM UTC
Appears so but never used it. See here for docs: https://www.ptc.com/en/support/article/CS166038?source=search
6-Contributor
Apr 23, 2025 3:29 PM UTC
Thanks for sharing! I have gone through the article. Now I have question that If this utility works, what should be the value of first argument that accepts which is CADName. Do I need to give the name of the object or oid. It would be helpful, if anyone share the example of the complete command to run.
