11-Garnet
Nov 30, 2016 8:15 PM UTC
Converting Single Windchill Server to a Cluster Configuration
Curious if anyone has changed from the single server to cluster configuration. Are there specific steps and do you use a load balancer? Thanks in advance!
Dec 5, 2016 4:25 PM UTC
Hi Bill,
Yes. It is possible.
High level steps:
1. Copy Windchill folders to other nodes.
2. Setup the cluster properties.
3. Setup the load balancer settings.
You can refer 'http://support.ptc.com/WCMS/files/168953/en/WCAdvDeployGuide.pdf' guide 'Configuring the Windchill Environment for Clustering' section for more details.
Thanks & Regards,
Ravi Kandepu.
Dec 6, 2016 3:37 AM UTC
Hello Bill,
Windchill monolithic to Cluster is possible with below Cluster properties in Master and slave after copying windchill folder from master to slaves.
1. Defining cluster properties on Master
Created a new xconf file clusterMaster.xconf under Windchill directory
wt.properties on Master node
          -> java.rmi.server.hostname=<master.company.com>
          -> wt.server.hostname=$(wt.rmi.server.hostname)
          -> wt.rmi.server.hostname=$(java.rmi.server.hostname)
          -> wt.httpgw.hostname=<loadbalancer.company.com> or <Server alias Name>
          -> wt.cache.master.slaveHosts=<slave1.company.com>,<slave2.company.com>,
< slave3.company.com>,<master.company.com>,<IP_Address for slave1>, <IP_Address for slave2>,<IP_Address for slave3>,<IP Address for master>
          -> wt.server.codebase=<http\://AiasName.company.com/windchill>
          -> wt.cache.master.codebase=<http\://master.company.com/windchill>
          -> wt.cache.master.hostname=<master.company.com>
<Windchill>/codebase/WEB-INF/ieStructProperties.txt on Master node
          -> ie.ldap.serviceName=<loadbalancer.company.com>or <Server alias Name>
1. Defining cluster properties on Slaves
wt.properties on Slave node
          -> java.rmi.server.hostname=<Slave1.company.com>
          -> wt.server.hostname=<Slave1.company.com>
          -> wt.rmi.server.hostname=<Slave1.company.com>
<Windchill>/codebase/WEB-INF/ieStructProperties.txt on Slave1 node
Load balancing can be done with Hardware load balancing as per PTC recommendation or Apache load balancing.
Please refer PTC document as given by Ravi mail above.
Nandish
