Converting WT file as End Item WT
I have 60 top level assemblies and I created wt part for the same. Now I need all 60 wt part to be converted as End Items. Can I do this in Windchill or should I remove association of all wt, delete wt's, create End item wt and then associate it again with respective assemblies?
