7-Bedrock
Mar 27, 2024 3:21 PM UTC
CORS Exception while calling Windchill REST Services
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.8
CORS issue in the Windchill while calling the Windchill REST Services from an external application
Here are the errors that I faced
Access to fetch at 'https://plm-test.intra.infineon.com/Windchill/servlet/odata/v1/Infineon/IFXParts('1231231')' from origin 'https://portal-graviteeio-sbx.icp.infineon.com' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
    Mar 28, 2024 2:09 AM UTC
    Try looking at CORS filter in Windchill\tomcat\conf\web.xml
    	<filter>
    		<filter-name>CorsFilter</filter-name>
    		<filter-class>org.apache.catalina.filters.CorsFilter</filter-class>
    		<init-param>
    			<param-name>cors.allowed.origins</param-name>
    			<param-value>null</param-value>
    		</init-param>
    		<init-param>
    			<param-name>cors.allowed.methods</param-name>
    			<param-value>GET,POST,HEAD,OPTIONS,PUT</param-value>
    		</init-param>
    		<init-param>
    			<param-name>cors.allowed.headers</param-name>
    			<param-value>Content-Type,X-Requested-With,accept,Origin,Access-Control-Request-Method,Access-Control-Request-Headers</param-value>
    		</init-param>
    		<init-param>
    			<param-name>cors.exposed.headers</param-name>
    			<param-value>Access-Control-Allow-Origin,Access-Control-Allow-Credentials</param-value>
    		</init-param>
    		<init-param>
     <param-name>cors.support.credentials</param-name>
     <param-value>true</param-value>
    		</init-param>
    		<init-param>
    			<param-name>cors.preflight.maxage</param-name>
    			<param-value>10</param-value>
    		</init-param>
    	</filter>
    	<filter-mapping>
    		<url-pattern>/*</url-pattern>
    	</filter-mapping>
    Kind regards,
    Dmitry
    amarjit7-BedrockAuthor
    7-Bedrock
    Mar 28, 2024 8:25 AM UTC
    Thanks for your response.
    Is the CORS exception need to be enabled in the Windchill\tomcat\conf\web.xml or the Windchilll\codebase\WEB-INF\web.xml
    18-Opal
    Mar 29, 2024 9:55 AM UTC
    Hello amarjit,
    Can you review kb article https://www.ptc.com/en/support/article/CS378185 ?
    KR,
    Charles.
    Apr 3, 2024 11:59 AM UTC
    Hi, I also struggled long with the cors topic. Until I finally found the problem.
     <filter-name>ContentCorsFilter</filter-name>
     <init-param>
     <param-value>http://localhost:4200</param-value>
     </init-param>
     <init-param>
     </init-param>
     <init-param>
     <param-value>GET,POST,OPTIONS</param-value>
     </init-param>
     <init-param>
     <param-value>Content-Type,X-Requested-With,Access-Control-Allow-Origin,Access-Control-Allow-Credentials</param-value>
     </init-param>
     </filter>
     <filter>
     <filter-name>ContentHttpHeaderSecurityFilter</filter-name>
     <filter-class>org.apache.catalina.filters.HttpHeaderSecurityFilter</filter-class>
     <init-param>
     <param-name>antiClickJackingOption</param-name>
     <param-value>ALLOW-FROM</param-value>
     </init-param>
     <init-param>
     <param-name>antiClickJackingUri</param-name>
     </init-param>
     </filter>
     <filter-mapping>
     <url-pattern>/servlet/WindchillAuthGW/wt.content.ContentHttp/viewContent/*</url-pattern>
     <url-pattern>/servlet/WindchillGW/wt.fv.master.StandardMasterService/doDirectDownload/*</url-pattern>
     <url-pattern>/servlet/WindchillGW/wt.fv.replica.StandardReplicaService/doDownload/*</url-pattern>
     <url-pattern>/servlet/WindchillGW/wt.fv.replica.StandardReplicaService/doIndirectDownLoad/*</url-pattern>
     <url-pattern>/servlet/WindchillGW/wt.fv.uploadtocache.DoUploadToCache_Server/doUploadToCache_Master</url-pattern>
     <url-pattern>/servlet/WindchillGW/wt.fv.uploadtocache.DoUploadToCache_Server/doUploadToCache_Replica</url-pattern>
     </filter-mapping>
     <filter-mapping>
     </filter-mapping>
     My problem was, that the tag cors.allowed.headers did not have the appropriate header information in it. This is just missing in the WNC help.
    Adding the above entries to the codebase/WEB-INF/web.xml  solved all my CORS problems.
