CPS 13.0.2.13 breaks HTTPS
Hi there,
I just realized, that the Critical Patch Set Bundle 13.0.2.13 changes the configuration value of wt.webserver.protocol in wt.properties.xconf from “https” to “http”.
“Server Status” in “Site → Utilities” then shows “SITE NOT RESPONDING” under section “File Servers”.
At this point You cannot access the home page, detail pages or workspace content.
Steps to reproduce:
To Fix the issue:
  • start Windchill - Shell and check with xconfmanager, where wt.webserver.protocol is defined
    xconfmanager -d wt.webserver.protocol
    That should give You something like this:
    Property information for 'wt.webserver.protocol':
    Values:
    - https
    Locations:
    - file:/D:/ptc/Windchill_13.0/Windchill/codebase/wt.properties.xconf, line 108
    Target File(s):
    - D:\ptc\Windchill_13.0\Windchill\codebase\wt.properties
  • Go to <Winchill Home>/codebase/wt.properties.xconf and change value ( aka “default”) back to “https”
    <Property name="wt.webserver.protocol" default="https"/>
I also saw something like this after CPS 13, took forever to figure out, another option to fix it is add the property to site.xconf
overridable="true"
targetFile="codebase/wt.properties"
value="https"/>
then xconfmanager -p
I wouldn’t recommend directly changing values in wt.properties.xconf but not judging I know everyone’s Windchill is different
Mat16-PearlAuthor
Yes.
I did something similar.
I created an external configuration file like  “d:\custom_configurations\my_configuration.xconf” and included this with
xconfmanager -i “d:\custom_configurations\my_configuration.xconf” -p
xconfmanager -d wt.webserver.protocol then gives me:
Property information for 'wt.webserver.protocol':        Values:        - https        Locations:        - file:/D:/ptc/Windchill_13.0/Windchill/codebase/wt.properties.xconf, line 108                                          - file:/D:/custom_configurations/my_configuration.xconf, line 9                              Target File(s):        - D:\ptc\Windchill_13.0\Windchill\codebase\wt.properties
