6-Contributor
May 26, 2026 8:36 AM UTC
Create a Manufacturing view via workflow
i am trying to find a way to create a manufacturing view for a wtPart in a workflow.
For example, when a promotion request is reviewed and the promotion object is Released, the manufacturing view should be automatically created. Until now this can be done manually via the menu: Actions → New → New view version.
Is this possible?
TDTAnswer
18-Opal
May 26, 2026 8:44 AM UTC
Hi ​@SS_14534388,
Yes, this is possible.
You will need to add the required logic in the Expression Robot to create the Manufacturing View.
TDT18-OpalAnswer
18-Opal
Hi ​@SS_14534388,
6-Contributor
May 26, 2026 10:04 AM UTC
Thanks for the reply! I manage to do that with some coding in an expression robot.
