Aug 24, 2024 2:06 PM UTC
Create Change Management based on state
We want to implement certain conditions for the creation of Change Management objects. Currently, only users with the Change Leader role can create change requests and change notices. We've enforced this restriction through policy administration.
Additionally, our customer has requested the following:
  • Change Requests can only be created when the Problem Report is in the "Accepted" state.
  • Change Notices can only be created when the Change Request is in the "Implementation" state.
  • Alternatively, the creation of Change Requests and Change Notices should only be possible after the execution of the "Create Change Request" and "Create Change Notice" actions.
How can I achieve this?
HelesicPetr
Aug 26, 2024 8:57 AM UTC
Hi @MI_10060660
Generally you can achieve it by customization.
Remove all actions from standard menu for creation CR, and CN
Allow it just in the detail page on the ChangeRequest and Problem report
Create own filter that shows his actions if the conditions are met
All is doable.
PetrH
Aug 26, 2024 11:52 AM UTC
How can I do this?
Sep 16, 2024 8:19 AM UTC
@HelesicPetr
