Apr 9, 2024 5:44 AM UTC
Create mount for root folder "vault1" failed.
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.0
Create mount for root folder "vault1" failed. Nested exception is: wt.util.WTException: Creation of subfolder below root folder "vault1" failed. A physical folder corresponding to the root folder mount path "D:\cnitWcVault\vault1" does not exist.
    HelesicPetr
    Apr 9, 2024 6:40 AM UTC
    Hi @ZL_10908440
    So create the folder D:\cnitWcVault\vault1 on the server disk drive.
    and grant a modify access to the user who run the Windchill service.
    PetrH
    Apr 10, 2024 3:52 AM UTC
    D:\cnitWcVault\vault1 exists. If it does not exist, the following error is reported:
    Create mount for root folder "vault1" failed. Nested exception is: wt.util.WTException: Some of the mounts are not valid D:\cnitWcVault\vault2 - not exist
    18-Opal
    Apr 11, 2024 10:34 AM UTC
    Hello ZL_10908440,
    Can you activate wt.fv logger ?
    KR,
    Charles.
