Nov 10, 2025 1:05 PM UTC
Creating Enterprise Data directly from Windchill UI
Version: Windchill 13.0
Use Case: User wants to have attribute that is shared across various views but at the same time Change-Management controllable. Enterprise Data looks like something good for that but I see no way to create it directly through UI, compared to Load File - https://support.ptc.com/help/windchill/plus/r12.0.2.0/en/index.html#page/Windchill_Help_Center%2FExpMPM_CreatingObjectsUsingLoader.html%23
Description:
Hello, according to this URL there is a way to create Enterprise Data using LoadFile (it requires some preferences setup but that's not so important).
Question now is - is there any OOTB Create wizard for this Enterprise Data, or is it only supposed to be created through load files?
Catalina
Community Manager
Nov 18, 2025 10:17 AM UTC
Hi @MWFemboy
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
MWFemboy10-MarbleAuthor
Nov 20, 2025 9:02 PM UTC
No worries Catalina, it turned out to be not so important on my end. Still, it's quite odd that such object can only be created together with WTPart but not later on (unless using LoadFile command with proper file input).
