3-Newcomer
Jan 20, 2023 8:54 PM UTC
Creating Multiple DMs Using an Excel Spreadsheet
Is there a way to create a PM Structure in excel, then upload the DMs into the Information Structure in Windchill?
This would bypass having to right click > insert new > insert new document a 100 times.
Dan
d_grahamAnswer
18-Opal
Nov 3, 2023 12:13 PM UTC
@DS_10053516 , you can load a part structure (or anything else for that matter) with a csv file.
This would be done in a Windchill shell so you’d need access to that.
If you want to load from a WTPart’s action menu, that’s doable too but it would require writing the utility to do it.
d_graham18-OpalAnswer
18-Opal
HelesicPetr
Nov 3, 2023 12:27 PM UTC
 Hi @DS_10053516
Check following knowladge Hub.
You can create excel spreadsheet and import the parts and structure from the excel.
You just need to keep correct format of the excel
CS319018 - Windchill PLM - Import from Spreadsheet
help > Import Job Monitor and Import Job Information Page
PS> excel format is not so userfriendly but it is possible.
PetrH
