11-Garnet
May 30, 2026 11:46 AM UTC
Creating New Windchill Redundant Server
We have monolithic Windchill Setup.
Details:
1. One Main Server
2. Replica Server 1
​​​​​​​3. Replica Server 2
4. Database Server
As failsafe  in runtime, if the main server goes offline due to (hardware issues, OS issue, Network issue, etc) there needs to parallel redundant server.
I have checked below articles about cluster for Windchill.
https://www.ptc.com/en/support/article/CS30922?source=search
https://www.ptc.com/en/support/article/CS436863?source=search
Questions:
What is the first step to move towards cluster or redundant environment?
Is it good idea to have new separate application server and new separate DB server as backup?(These application and DB server needs to have same configuration)
Considering emergency on application and database servers as well, then is cluster a good option?
or is there a other solution that is available for situations like this?
18-Opal
Jun 1, 2026 6:12 AM UTC
You should consider setting up your servers in a Master-Slave configuration, resulting in a clustered application environment.
