Dec 11, 2014 10:11 AM UTC
creating textarea wherein I can manually enter values.
I have written datautility extending AbstractDataUtility but textarea is not visible in table builder.Code is as follows.
public class AttributeTextAreaDataUtility extends AbstractAttributeDataUtility {
public Object getDataValue(String component_id, Object datum, ModelContext mc) throws WTException
super.getDataValue(component_id, datum, mc);
TextArea textarea = new TextArea();
TextArea textArea = GuiComponentUtil.createTextArea(1, 2, 3 );
//textArea.setColumnName(AttributeDataUtilityHelper.getColumnName(component_id, datum, mc));
textarea.setValue(getAttributeDisplayValue(component_id, component_id, datum, mc));
textarea.setReadOnly(true);
textarea.setWidth(40);
textarea.setHeight(5);
//textarea.setName(component_id);
return textarea;
private static String getAttributeDisplayValue(String attributeName,String componentId, Object datum, ModelContext mc)
throws WTException
Object raw_val = UtilityHelper.getRawValue(attributeName, datum, mc);
String value = UtilityHelper.getStringValue(raw_val, componentId,datum, mc);
return value;
PrabhashAnswer
Dec 12, 2014 12:26 PM UTC
Hello Hrishikesh,
Have you created a custom builder class? Are you trying to hook the datautility to an attribute from builder or is this attribute is OOTB attribue?
But whatever the case may be you dont need these many lines of code in a datautility to display a Text Box.
Just one method inside your datautiliy class is sufficient:
ModelContext modelcontext) throws WTException {
TextArea textArea = new TextArea();
textArea.setId(component_id);
textArea.setEditable(true);
textArea.setLabel("MY TEXT AREA");
textArea.setWidth(20);
return textArea;
-Prabhash
Prabhash1-VisitorAnswer
Hello Hrishikesh,
return textArea;
-Prabhash
hmungekar1-VisitorAuthor
Dec 12, 2014 12:50 PM UTC
I tried with the above mentioned code but still i am not getting textbox wherein i can manually enter values.I have created a table builder wherein I hav added customized Data utility as a column.
Dec 12, 2014 1:18 PM UTC
Hrishikesh, I have used the same code many a times without any error. If you could send me your code may be i will be able to debug it and help you out. And finally do you want a Text Box or a Text Area?
-Prabhash
Dec 12, 2014 1:33 PM UTC
I have attached table builder code and customized data utility.i have attached snap shot of the output im getting
Dec 12, 2014 11:41 PM UTC
Just Curious...is control going inside your datautility class? Where and how did you register the datautility?
Dec 13, 2014 9:45 AM UTC
yes code inside data utility is working as i had written system.out.println inside it.i hav registered it inside service.properties
