7-Bedrock
August 27, 2024
Creating WTPart using InfoEngine based webservice
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.0
i have created the infoengine based webservice for creating a wtpart. While running client some errors are persisting.
Exception in thread "main" com.ptc.jws.service.org.myorg.partservice.Exception_Exception: com.infoengine.util.IEException; nested exception is:
java.lang.NullPointerException
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
at com.sun.xml.ws.fault.SOAPFaultBuilder.createException(SOAPFaultBuilder.java:114)
at com.sun.xml.ws.client.sei.StubHandler.readResponse(StubHandler.java:223)
at com.sun.xml.ws.db.DatabindingImpl.deserializeResponse(DatabindingImpl.java:176)
at com.sun.xml.ws.db.DatabindingImpl.deserializeResponse(DatabindingImpl.java:263)
at com.sun.xml.ws.client.sei.SyncMethodHandler
Here are the errors that I faced
at com.sun.xml.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:88)
at com.sun.xml.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:61)
at com.sun.xml.ws.client.sei.SEIStub.invoke(SEIStub.java:131)
at com.sun.proxy.$Proxy44.createPart(Unknown Source)
at org.myorg.PartClient.main(Unknown Source)
    7-Bedrock
    August 27, 2024
    Webservice :
    <%@page language="java" access="internal|http|soap"%>
    <%@ taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
    <%@taglib uri="/com/infoengine/tlds/iejstl.tld" prefix="c"%>
    <!--com.infoengine.soap.rpc.def
    @param String new_Part_Name
    @return String ${output[0]result[0]}
    String part_Name = getParam("new_Part_Name").toString();
    <c:set var="${output[0]result}" value="successfully Created" />
    <ie:webject name="Query-Objects" type="OBJ">
        <ie:param name="INSTANCE" data="$(@FORM[]supporting-adapter[*])" delim="!" valueSeparator="!" default="<%=com.infoengine.au.NamingService.getVMName()%>"/>
        <ie:param name="TYPE" data="wt.pdmlink.PDMLinkProduct"/>
        <ie:param name="WHERE" data="name=Fan"/>
         <ie:param name="GROUP_OUT" data="product"/>
    </ie:webject>
    <ie:webject name="Create-Objects" type="ACT">
    <ie:param name="CONTAINER_REF" data="$(product[]obid[])"/>
         <ie:param name="FIELD" data="name=<%=part_Name%>"/>
        <ie:param name="TYPE" data="wt.part.WTPart"/>
    </ie:webject>
    Client :
    package org.myorg;
    import com.ptc.jws.client.handler.*;
    import com.ptc.jws.service.org.myorg.partservice.*;
    import java.util.Arrays;
    import java.util.List;
    public class PartClient
        public static void main ( String [] args ) throws java.lang.Exception
     PartServiceImplService service = new PartServiceImplService();
     PartServiceImpl port = service.getPartServiceImplPort ();
    for(String arg : args){
    port.createPart(arg);
    System.out.printf ( "Part Created Successfully "+arg);
    Error:
    Community Moderator
    August 30, 2024
    Hi RG_10893406,
    Thank you for your question.
    Vivek N
    Community Moderation Team.
