3-Newcomer
Oct 26, 2026 3:06 AM UTC
Creator cannot manage Team members
I am using Windchill PDMLink Release 13.1 and Datecode with CPS 13.1.0.0 Requirement: For custom part type "CBB Part", ONLY its Creator should maintain team members (add/remove). Tried independently (both failed): Approach A - Policy Administration: Granted "Full Control" to dynamic role "Creator" in /Default/PDM and /System domains. Approach B - Lifecycle Template: Granted "Full Control" to the "Owner" role directly in the lifecycle template. Current Issue: Only the Administrator account can see the "Add/Remove Member" options. The Creator cannot see these options on the Team page. Questions: What is the standard configuration to achieve this? Are we missing a preference (e.g., Access Permission Configuration (PDM)) or facing domain priority issues? What is the correct domain and permission setup?
Oct 26, 2026 10:08 AM UTC
Check the Profile of the Creator and whether they have the add/remove action in the profile actions
joe_morton
Oct 27, 2026 12:28 AM UTC
This could also be a license issue. I believe a higher license is needed to administer teams than to just edit documents. Double-check what license is assigned to the Creator, and test giving a higher license.
18-Opal
Oct 27, 2026 6:21 AM UTC
When you say Team page, are you referring to the Team page shown below?
