Mar 8, 2026 4:28 PM UTC
Creo 12 CAD Worker - STEP export profile not loading from config.pro always loding the ap203_is
I am using Creo Parametric Release 12.4 and Datecode12.4.2.0
Question: What is the supported and working method in Creo 12 for a headless CAD Worker to automatically use a custom STEP export profile with ap242?
this is what i did already.
Subject: Creo 12 CAD Worker - STEP export profile not loading from config.pro
Details:
Creo 12 used as Windchill CAD Worker (headless/batch mode)
STEP export always defaults to ap203_is regardless of config.pro settings
Startup directory: D:\ptc\proe_setup_prod_01\
All files present in startup directory: def_profile_MBN_MBD.dep_step, def_profile.dep_step, config.pro
Already tried without success:
export_profiles_step def_profile_MBN_MBD D:\ptc\...\def_profile_MBN_MBD.dep_step
intf_profile_dir D:\ptc\proe_setup_prod_01\
intf3d_out_default_profile def_profile_MBN_MBD
step_export_format ap242
Setting profile via File → Options → Data Exchange → Setup Export Profiles
Renaming profile to def_profile.dep_step
MikeBennett
Mar 10, 2026 11:38 AM UTC
Hi @AB_10220278 ,
While CAD workers are technically Creo Parametric, the specific usecase for CAD workers falls under the Windchill Visualization category so you may find a more focused set of members in that community:
https://community.ptc.com/t5/forums/filteredbylabelpage/board-id/Windchill/label-name/windchill%20visualization
As far as Creo goes, what happens in a active Creo session with the configuration options you've tested for the worker? Manual session on screen, not headless/batch.
Mike
MikeBennett
Hi @AB_10220278 ,
Mike
3-Newcomer
Aug 15, 2026 6:19 PM UTC
​@AB_10220278 , We’ve run into the same problem. Did you find a solution?
3-Newcomer
Aug 15, 2026 7:17 PM UTC
Actually, we’ve figured it out. Remove .dep_step from the path in export_profiles_step.
e.g. def_profile.dep_step would be:
export_profiles_step F:\PTC\CAD_Worker_12_4\profiles\def_profile
