Apr 16, 2013 2:54 PM UTC
Creo hangs on Retrieval Window after Crash
Hello all,
We are running Creo 1.0 M050 w/ Windchill 10.0 M030.
After Creo crashes, I restart the application and it will then hang on the "Retrieval" Window ("Creo Parametric was not closed properly...Click retrieve or continue"). I am pretty sure it has to do with Windchill - in particular two lines in my config file. I know this because if I remove these lines from the config, Creo will not hang on the retrieval window upon startup.
The config file lines in question are:
pro_format_dir wtpub://Windchill/Libraries/Library/Formats
start_model_dir wtpub://Windchill/Libraries/Library/Formats
If I start Creo after a legitimate shutdown (not after a crash), everything loads just fine with no hangs.
Any ideas?
Andri
May 27, 2013 11:28 AM UTC
This Option worked for me
last_session_retrieval no
May 23, 2013 3:09 PM UTC
Some times even after a shutdown you can't get in.
I could resolve it by removing the folder C:\Documents and Settings\%USERNAME%\Application Data\PTC\.ptcm1912
But this cleanups your local workspace . You will lose your un-uploaded modifications.
Do someone have a better solution?
2-Explorer
Feb 19, 2014 6:40 PM UTC
The ptcm1912 is the browser cache. Not the wgm folder.
You can remove this folder and will not lose any of the unsaved work to server.
May 23, 2013 5:49 PM UTC
I've got a ticket in with PTC on this currently. I'll let you know what they come back with.
May 28, 2013 6:46 PM UTC
Aziz,
that config option works for me as well. Never used the retrieve much anyway...
Andri
Feb 19, 2014 12:01 AM UTC
I've got an open call on this as well. I'm able to repeat the issue so I'm hoping I'll have some success with PTC support.
Apr 4, 2014 4:37 PM UTC
It looks like PTC has taken this issue seriously. I've got an SPR and they've created a customer service note as well CS164045. The issue hasn't been resolved, but they believe that it is a problem. Step one complete.
Oct 30, 2015 6:38 PM UTC
Robert,
I looked up this SPR, and in it it says they have no plans to fix. I tried to set the config option, but that did not work for me.
Dennis Rehmer
Dec 8, 2014 3:40 PM UTC
I have exactly the same problem, can't do anything about it. Tried deleting the folders mentioned by Joao, didnt help. I cant even start Creo because of it.
23-Emerald II
Dec 13, 2014 1:29 AM UTC
Milosz,
Are you able to get Creo to start if you rename the workspace cache folder (.wf)? If so, then the cache was probably corrupted too much to be able to recover.
