Nov 30, 2017 2:58 PM UTC
Creo Illustrate direct-link
Has anyone used the direct connection between Creo Illustrate and Windchill that comes with Illustrate 4.1? What are the pros/cons you've experienced with the direct connection?  I prefer the concept of a workspace in WWGM where we can do work before uploading that to commonspace in Windchill. I'd like feedback before we commit to upgrading to 4.1.
Nov 30, 2017 3:42 PM UTC
Out of curosity what version of PDMLink are you using? You need 11.0 M030 to use 4.1 at all and you can still use the WWGM.  That is how I am currently running.  Real like some of the improvements in 4.1.
tmenadue1-VisitorAuthor
Nov 30, 2017 4:34 PM UTC
We're on WC 11.0 M030.
I cannot find any instruction or documentation on how to search for my content using the direct connect. It allows me to browse through the folders, but you can imagine how that goes. Browsing through WC is terribly slow. I expected to be able to type in my number in the search field, just like WC...and that doesn't work.
Nov 30, 2017 4:44 PM UTC
Did you need to do anything different in the setup?  Or does it just work out of the box that way?  How did you connect to the server?
