6-Contributor
Jun 19, 2023 7:32 PM UTC
Creo keeps spinning when connected Windchill.
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
Opening Creo with connected to Windchill, it just keep spinning and not able to connect to Windchill.
    joe_morton
    Jun 19, 2023 7:44 PM UTC
    Here's a few troubleshooting tips:
    • Check to make sure the login window isn't in the background somewhere, or maybe on another monitor.
    • Confirm that you can access Windchill using the URL directly in a web browser such as Chrome
    • try restarting your computer
    klakshmi6-ContributorAuthor
    6-Contributor
    Jul 27, 2023 5:14 PM UTC
    Hello Joe,
    i do an alternative way to fix this issue. But i'm just wondering why this happens frequently to the users. I restart the system clear the Creo cache and it works. I've not seen this issue before, i'm trying to find the root cause of this issue.
    Kiran
    jbailey
    18-Opal
    Jun 20, 2023 12:43 PM UTC
    Which version of Creo? Make sure you have the browser type in the config.pro set to chromium
    6-Contributor
    Jul 27, 2023 5:15 PM UTC
    Hello JB,
    we are using Creo 4.0 M150 and the browser is set to Chromium.
    Kiran
    Jul 27, 2023 6:10 PM UTC
    Creo 4 is not supported on Windchill 12!
