7-Bedrock
Oct 11, 2023 7:30 AM UTC
Creo Shows Not responding, after checkout the part.
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS07
While check out the drawing from Windchill, Creo takes much time to load. it shows Not responding.
Oct 11, 2023 12:57 PM UTC
What version of Creo are you using?
Is it a single part or a complex assembly?
Dobi
Oct 11, 2023 7:02 PM UTC
Are you checking out directly from Commonspace?
It may be that if your workspace is not empty, Windchill is running into issues with adding files to workspace. That can often make it hang.
