Jun 10, 2015 11:33 AM UTC
Creo View default window size ?
Is it possible to change the default size when Creo View launches from the info page thumbnail ?
Looking at the URL it looks like:
javascript:createCDialogWindow('/Windchill/wtcore/jsp/wvs/edrview.jsp?url=http://windchill.servometer.local/Windchill/servlet/WindchillAuthGW/com.ptc.wvs.server.util.WVSContentHelper/redirectDownload/18001_drw.pvs?u8&HttpOperationItem=wt.content.ApplicationData%3A61964475&ContentHolder=wt.viewmarkup.DerivedImage%3A61964456&objref=OR%3Awt.viewmarkup.DerivedImage%3A61964456', 'ProductViewLite', '800', '650','0','0')
If I manually change the '800" and '650' values at the end of the URL, Creo View will launch at the desired screen size.  Is there any way to modify the windchill files that control launching Product View to a new default window size ? We're running 9.1 and using Creo View 3.
Jun 10, 2015 12:09 PM UTC
Windchill\codebase\action.properties file contain urlinfo properties specific to specific actions that controls the pop up window size. not sure if open in product view or creo view action is listed in action.properties file.
Hope it helps !!!
Shreyas
ehowanice12-AmethystAuthor
Jun 11, 2015 11:47 AM UTC
Shreyas - Thanks for the reply.  Looking at the action.properties file there are listings for:
# Open in ProductView Clipboard Table Action - moreurlinfo must match values in UIHelper and
# Open in ProductViewLite Clipboard Table Action - moreurlinfo must match values in UIHelper
no listings for Open in Productview / ProductviewLite from info page or thumbnail.
may open a case with PTC although I have a feeling they will be of limited help.
