Jul 30, 2018 9:09 PM UTC
Creo View Failed to load the file.
The following message is the error I receive when trying to view a Windchill representation in Creo View:
"Failed to load the file. Check the Adobe Acrobat or Adobe installation."
My machine is currently running Creo View 3.1 M010 build 27. Is there anything I can troubleshoot?
TomU
Jul 31, 2018 1:30 PM UTC
Viewing PDFs in Creo View also requires Adobe Acrobat or Adobe Reader to be installed locally.
Do you have Adobe Acrobat Reader loaded?
Is it the right version to run with CreoView 3.1?
mastachef1-VisitorAuthor
Jul 31, 2018 2:02 PM UTC
Currently have Adobe Acrobat Reader 2017 Release 2017.011.30096 installed
TomU
Jul 31, 2018 2:10 PM UTC
That's more than likely the problem.  Either roll back to an older version of Reader or upgrade to a newer version of Creo View.
You may also want to vote for this product idea:
https://community.ptc.com/t5/Addtl-Creo-Ideas/Embed-PDF-viewer-within-Creo-View/idi-p/476631
TomU
Jul 31, 2018 1:33 PM UTC
Here is the version you need installed for Creo View 3.1 M010:
"PDF viewing supported with Adobe Reader X (10.x), XI (11.0), DC"
Jul 31, 2018 7:41 PM UTC
'Failed to load the file. Make sure that the registry entry of Adobe Acrobat or Adobe reader points to the correct installation. If the registry entry is correct, and re-installing Adobe Acrobat or Adobe Reader, and then restart'
Performed an uninstall and re-install of both application to no avail.
 https://www.ptc.com/support/-/media/00548DEEA08F4097A946C928F3E090DF.pdf?sc_lang=en
Should I/Can I upgrade to Creo View 5.0 per the chart? I cannot seem to find the correct version of Creo View which will run successfully with Windchill.
BenLoosli23-Emerald IIIAnswer
Jul 31, 2018 8:01 PM UTC
