Aug 11, 2015 3:52 PM UTC
Creo View windows partially off-screen
When opening  a drawing in Creo View (from Windchill running in IE10) the new window appears half off the screen for many of our users. They all report that this started happening around the same time, though we didn't hear about it for about a month after because nobody thought it was serious enough to report to the IT team.
Have any of you seen this issue? It's not having a detrimental effect on any of the users, but we're not sure why it started in the first place.
2-Explorer
Aug 11, 2015 4:05 PM UTC
Hi Thomas,
I remember observing this issue on IE8 because of this https://support.microsoft.com/en-us/kb/974537
It is worth trying the reg entry FEATURE_FORCE_POPUPS_ONTO_MONITOR_KB974537
Binesh Kumar
Barry Wehmiller
tsmith-31-VisitorAuthor
Aug 11, 2015 7:01 PM UTC
Binesh,
Thanks for the suggestion. Unfortunately, it doesn't seem to have an effect on the Creo View window.
2-Explorer
Aug 11, 2015 7:08 PM UTC
Hi Thomas,
It worked for me more than a couple of times. Could you try this setting under Wow6432Node
1. Open registry editor – regedit
Start > type regedit in the search box > hit enter
2. Browse to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main\FeatureControl
3. On the Edit menu, point to New, and then click Key.
4. Type the following key name, and then press ENTER:
5. On the Edit menu, point to New, and then click DWORD Value.
6. Type iexplore.exe, and then press ENTER.
7. Right-click iexplore.exe, and then click Modify.
8. In the Value data box, type 1, and then click OK.
Binesh Kumar
Barry Wehmiller
