3-Newcomer
Nov 24, 2026 4:18 PM UTC
CS483249 for Windchill 12.1.1.2?
One of our client is using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.2. We have seen the vulnerability report in case CS483249, where version 12.1.1 is not mentioned (while 12.0.2 and 12.1.2 are). We would like to know whether it is necessary to install any patch or apply any workaround.
Nov 24, 2026 6:54 PM UTC
Windchill 12.1.1.x was never intended to be a long term Windchill solution. It is out of date and no longer supported. I realize that some of the other versions listed are also no longer supported, but those are the ones that PTC designated as long term solutions. Prior to the release of Windchill 2027.x, the releases that had the 3rd digit of a 2 (11.1.2.x, 12.1.2.x, 13.0.2.x, etc) are the long term solution releases.
