6-Contributor
May 11, 2026 9:12 AM UTC
Custom attributes on Product / Library / Project contexts: best practice?
In my current project, I need to define custom attributes on context objects (Product, Library, and Project).
I'm wondering what the recommended approach is:
  • Subtyping the OOTB context types (wt.pdmlink.PDMLinkProduct, wt.inf.library.WTLibrary, wt.projmgmt.admin.Project2) to add the attributes on the subtypes, or
  • Modifying the OOTB types directly through the Type and Attribute Manager?
My main concerns are upgrade safety and long-term maintainability. Subtyping feels cleaner, but I'm not sure if context types behave differently from regular object types in that regard, particularly when it comes to container creation and template resolution.
Does PTC have any official documentation?
Thanks in advance.
avillanueva
23-Emerald II
May 11, 2026 10:28 AM UTC
Do you mean Soft typing or sub-typing. Subtyping would be creating a modified Java class subtype of that object. Soft Typing would be via the Type and Attribute manager? Strongly recommend soft typing since there is no DB modeling or custom classes involved.
As for adding attributes to the main object or what I assume you meant, soft typing, you need to ask yourself if these attributes would be applicable to all instances or could come along for the ride. Remember when you create a Product, Library or Project, you need to answer at time of creation which soft type you mean to create. There is no going back, no changing your mind and no deletion. Far easier to avoid that decision and deal with the attributes.
You can change your mind on attributes, remove them or change them. You can be assured that soft types or custom addition attributes will be supported with upgrades and long term maintainability.
https://support.ptc.com/help/windchill/r13.0.2.0/en/#page/Windchill_Help_Center/typeattr/TypeMgrAbout.html
7-Bedrock
May 15, 2026 11:08 AM UTC
Soft typing is the best way to do that. I would not disturb OOTB Context types if you are expanding the data model. So that the future need for seperate sub types is already factored in. You are future proof by creating a sutype (via softyping in UI).
Regarding the attributes itself, how many are being considered? If the need is to have too many attributes, well, can better model it as a Part in that context. Further, Part can be classified but not the Contexts.
Be wary of the data model expansion and take a call.
