May 14, 2015 7:19 PM UTC
Custom Number Sequences
Does anyone know how to find out what custom number sequences have been created in Windchill? I have an oracle database and want to see the sequences as well as what they look like (Starting number and increment). Any thoughts would be appreciated.
Brian
8-Gravel
May 15, 2015 3:04 PM UTC
Brian,
The WC OOTB sequences are documented in the Windchill Help Center under "Out-of-the-Box Schemes". By default they start at "1" with leading zero padding. I've attached a screen shot.
Russ
bwilson-21-VisitorAuthor
May 15, 2015 6:12 PM UTC
Russ,
Thanks for the info. What I really am looking for is how to find out
about any custom sequences that have been created. I found some code I think
will work but I haven’t tested it yet.
select substr(sequence_owner,1,10) "OWNER",
substr(sequence_name,1,25) "SEQ NAME",
substr(to_char(min_value),1,3) "MIN",
max_value "MAX",
increment_by "INC",
cache_size "CACHE",
last_number "LAST NUM"
from all_sequences
order by 1 asc, 2 asc;
Brian
May 15, 2015 6:15 PM UTC
I believe that you can find your custom series by searching for wt.series.* properties in <Windchill_Home>\codebase\wt.properties
May 20, 2015 7:46 PM UTC
Thanks for all the updates. I really appreciate it
