2-Explorer
Oct 18, 2014 7:06 PM UTC
Custom role(s) available for team
We have created 3 new custom roles and I can see the roles at Org. level roles and Product. They are not available to select when assigning roles editing a team template.
I remember there is a something else I need to set but I do not have my notes with me. I have added the roles to the 'Fixed roles to promote" in preferences.
Thanks for any help. Kathy
Oct 18, 2014 9:25 PM UTC
Check that enabled column shows true for them at the organization level.
Sent from XFINITY Connect Mobile App
Oct 19, 2014 12:41 PM UTC
Also, try to do a MakeJar and restart the server (after clearing the cache).
Oct 29, 2015 10:44 AM UTC
Kathy,
did you resolved your issue?
We've the same issue and we don't know how to resolve it.
thanks, roberta
BenPerry
Oct 29, 2015 10:49 AM UTC
Roberta Rollo‌,
Here are some other things you can try.  If you want to use in a Team Template, and adding them at org level in the UI doesn't work, then probably what is needed is to modify RoleRB file.
Assign participant to a role
how to add new roles not existed by default in windchill
Oct 29, 2015 12:08 PM UTC
Thaks Ben, but nothing changed.
I can see my new roles in Product Team level and any interfaces level but I can't see the new roles by the applet (team administrator).
Following the steps followed:
1. we changed  roleRB.rbinfo  under <WT_HOME>\wt_custom\project
2 . we ran :
ResourceBuild.sh wt.project.RoleRB true
ant - f bin/tools.xml bundle_custom -Dbundle.input=registry
ant -f codebase/MakeJar.xml custUpdate
3. Stopped Windchill (clear the cache tomcat and  <wt_home>\tasks\
