Mar 6, 2023 10:29 AM UTC
Custom SaveAs in Windchill
I would like to replicate the OOTB Save As feature. The purpose is to get the custom attributes value from Users for populating new name/number/filename through custom wizard.
Using EnterpriseHelper.service.saveCopy(oldepm,newepm) helps me achieve half of the requirement. The problem here is while opening the newly created 2D Drawing in Authoring Application, it throws pop-up message like this new 2D still referring the old 3D Model. In OOTB save as, it does that from Windchill itself.
HelesicPetr
Mar 6, 2023 11:40 AM UTC
Hi @MN_10518175
The issue can be that you make a copy separately one by one I guess.  I may be wrong.
Try to collect all objects and use to create copy following method
RevisionControlled[] input = new RevisionControlled[]{model, drawing};
EnterpriseHelper.service.newMultiObjectCopy(input);
PetrH
HelesicPetr
Hi @MN_10518175
PetrH
Mar 7, 2023 6:24 AM UTC
Thanks for your valuable suggestions.
After changing the logic using above API, authoring application doesn't show the above error popup. The only thing is the new drawing's representation still holds old value in drawing table. If perform OOTB save as, post republish, the value changes in representation. Could you please provide some way to achieve the same.
HelesicPetr
Mar 7, 2023 6:59 AM UTC
Hi @MN_10518175
The point of the old visualization is that you may not send the new object to visualization queue
or your visualization worker is not set to regenerate drawing during the visual process.
PetrH
