Jul 14, 2020 7:51 PM UTC
Customizing Export to PDF template
I am trying to customize the BOM export to PDF under the structures tab. Any changes I make to the XSLFO.XSL file do not seem do anything. I'd like to add the filename, company name/logo in the header and change the color scheme. Does anyone have any tips? Do I need to run a command to update the template files once they are edited?
Jul 15, 2020 12:29 PM UTC
This would need customization. I had created a PDF export (with customer logo) for one of my customer, I can share sample code and related files with you. You can reach me at karthik@teamspringg.com OR ketan@teamspringg.com .. and I will revert back with file and steps.
Karthik
Mar 14, 2024 8:54 AM UTC
Hi Karthik,
Could you share the code also with me? We have a similar requirement and we were thinking initially to use an excel template.
Alex
HelesicPetr
Mar 18, 2024 8:45 AM UTC
Hi @Alex1988
You can use the excel file as a template with all formatting as you need.
You just need to write a code that load this template fill it with your data values ,and save as a new excel file.
If you need PDF you need to find any excel to pdf convertor library, or you can use itext to generate own PDF directly without excel file.
PetrH
