3-Newcomer
Oct 20, 2023 8:29 PM UTC
Data Dictionary, Defintion and table for mBOM
Hello Guys,
I am new to this forum and windchill as well. I am looking for data dictonary, defintion for field attributes and table level information. For instance:- Defintion of Product Code wrt to windchill and which table in windchill contains all mBOM related infromation etc.. I would appreciate if you could help me with this!
Puneeth
Rocket_Max
Oct 23, 2023 2:23 AM UTC
Hello @PPuneeth
Currently, PTC does not have a similar document as it is.
You can refer to the following content to try to obtain the information you need
Introduction
User can access UML diagrams for desired Windchill types using the following steps:
Disclaimer
This requirement is out of the scope of PTC Technical Support
  • PTC can't provide any document regarding the Windchill PLM database and data model. It's a PTC proprietary
  • There is no such full documentation of all UML diagrams
  • PTC does not authorize any reverse engineering against Windchill Database and Java classes
The following articles help with writing customization and business reporting.
Table of content
General
  • CS357942  - Windchill Versioning Data Model
  • CS253668  - Overview of the meta model and related APIs in Windchill
  • CS351959 - Object Relationships for Report Building
  • Database Documentation:
    • Oracle: CS352575 - How to generate Windchill PLM Database Doc for Oracle Database
    • CS51689  - Understanding Database tables relationships to generate Queries or build Reports in Windchill PDMLink
Object Reference
  • CS112668  - Object Reference APIs in Windchill
  • CS346238  - What's ObjectReference and difference from WTObject in Windchill PDMLink
Link Objects
  • CS131357  - Overview of Link objects in Windchill PDMLink
Preferences
  • CS64896  - About Preference Database Table in Windchill PDMLink
EPM
  • CS119448  - Where to find information about the EPM data model in Windchill PDMLink
WVS
  • CS361466  - Windchill PLM Visualization Data Model
Principal
  • CS188216  - How to get the UML relation among WTUser/WTPrincipal/WTPrincipalReference objects in Windchill PDMLink?
  • CS94037  - What is the relationship between WTUser, remoteobjectinfo and remoteobjectid tables in Windchill PDMLink database
Change Management Objects
  • CS63595  - Understanding Change Management objects and their relations in Windchill PDMLink
  • CS334442  - Is it possible to determine whether a change object uses the Legacy or Flexible data model through windchill UI in Windchill PDMLink
Workflow
  • CS153902  - Windchill Data Model for Workflow related objects in Windchill PDMLink
Options and Variants
  • CS357952  - Basic Data Model for O&V basic expression in Windchill PDMLink
MPMLink Enterprise Data
  • CS262214  - General documentation on Enterprise Data type used in Windchill MPMLink
SIM
  • CS219370  - Need more information about Data Models in Windchill Service Information Manager (SIM)
Troubleshooting
  • CS247782  - Data model documentation is not available under codebasewbmhelp in Windchill Bulk Migrator 11.0
  • CS52984 - Location of HTML version of UML diagrams in Windchill PDMLink 10.0 (ptc.com)
  • CS252190  - Windchill Data Model (Information Model Diagram) documentation is not available.
  • CS17170  - Accessing the description of the data model via the UI fails with error in Windchill PDMLink 10.0 C000
Rocket_Max
Hello @PPuneeth
Introduction
Disclaimer
Table of content
General
Object Reference
Link Objects
Preferences
EPM
WVS
Principal
Workflow
SIM
Troubleshooting
