Apr 28, 2010 1:43 PM UTC
Data Utility
Hello All,
I want to use a text box and a button in a single row in Attributes table. How can I achieve this in a JCA attributes table. ? Is it possible through data utilities ?
If anyone has done anything similar or anyone has created a GuiComponent Data utility, can you please explain the procedure to do so. Any help will be appreciated.
Praseeth M
Apr 29, 2010 6:57 PM UTC
Hi Praseeth,
Your datautility should extend the
com.ptc.core.components.factory.dataUtilities.DefaultDataUtility.
--> Override the method getDataValue(String s, Object obj, ModelContext
modelcontext)
--> In this method create an arraylist of GUIComponents that you want to
tile
--> Create MultiValuedInputComponent passing ur arraylist
---> Return the MultiValuedInputComponent
Murugesh
On Thu, Apr 29, 2010 at 11:54 AM, Praseeth Moothedath <
-> wrote:
> Hi Murugesh,
> How do I render the components ? Should I extend the GuiComponent class
> and override teh draw() method ? And inside teh draw method how do I
> actually render the components ?
> I am in fact, stuck up here. Smiley Sad
> Thanks ,
> Praseeth M
> +91-9176687882
May 2, 2010 5:35 AM UTC
Thanks Murugesh. It worked !!! I used only the GUiComponentArray. And i
could render a textbox and pushbutton in the Attributes table. I used JS, to
call another JSP at the click of teh button. Thanks for the help.
Apr 10, 2024 1:30 PM UTC
Hello Praseeth/Murugesh,
I am trying to implement similar functionality for two attributes one is combobox and another is a text area.
I want to see plus button of UI for both attributes together. Can you please share exactly how you implemented MultiValuedInputComponent  by passing arraylist of component
Thanks & Regards,
Manisha
HelesicPetr
Apr 10, 2024 1:53 PM UTC
@MP_10433217
It is better to ask a new question then react to the 14 years old thread 😄
example
public Object getDataValue(String columnName, Object rowObject, ModelContext modelContext) throws WTException
ArrayList<AttributeGuiComponent> urlLinks = new ArrayList();
UrlDisplayComponent urlDisplay = new UrlDisplayComponent(columnID, null, null, null);
urlLinks.add(urlDisplay);
Label labelComponent = new Label(((ConfigPropertiesItem) rowObject).getFileName());
urlLinks.add(labelComponent );
return new MultiValuedDisplayComponent(urlLinks);
PetrH
