May 3, 2023 11:44 AM UTC
Database Migration General Questions
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS03
General Questions -
1.) Our Windchill database is 64 bit Oracle database 12c Release 1 - 12.1.0.2, can I apply latest patch i.e. CPS 22.
2.) Our Windchill database is 64 bit Oracle database 12c Release 1 - 12.1.0.2, to what version of SQL Server database can it be migrated.
May 3, 2023 1:12 PM UTC
1.) A CPS will have the same database compatibility so applying the CPS22 won't change compatibility with Oracle 12C as CPS03.
2.) Migrating from Oracle to SQL Is a completely different project. You should look into the Oracle to SQL Migration tool. Reference here:
https://www.ptc.com/en/support/article/CS263851
