Oct 20, 2025 7:37 PM UTC
Date Selection
Version: Windchill 13.0
Use Case: I would like to be able to prevent users in my Windchill instance to pick dates in the future when populating a timestamp attribute.
Description:
Can this be achieved?
joe_morton
Nov 12, 2025 7:52 PM UTC
It sounds then what you might need would be some Listener and custom code. You could have the Listener run when the part instance is created, and validate that the date is not in the future. I think the out of the box constraints only allow for setting a static date range.
avillanueva
23-Emerald II
Oct 22, 2025 12:53 PM UTC
If this is in a workflow, yes this can be done but you need a check step after or you can add code to the transition section of the workflow task to do a date compare. Is there a particular UI entry section that you are looking to validate? There is also creating a validator if its a different part of the UI, not workflow related.
Oct 28, 2025 7:04 PM UTC
Hi. I am looking to prevent users from picking a date in the future when populating an attribute of a part instance, for example. So, I don't believe this is workflow related.
joe_morton
Community Moderator
Oct 27, 2025 9:27 PM UTC
Hi @BF_13811900,
Anurag
