May 26, 2022 5:44 PM UTC
Default Bind DN for OpenDJ
Has anyone found a way to set the default Bind DN for OpenDJ? It defaults to "CN=Directory Manager" and I would like it to default to "CN=Manager" instead.
3-Newcomer
May 26, 2022 11:04 PM UTC
You can simply add the alias "CN=Manager" to the default one "CN=Directory Manager" (or the reverse).
It's in the config.ldif file (<OpenDJ_HOME>/config/config.ldif). Look for "Directory Manager" and add the required line:
ds-cfg-alternate-bind-dn: cn=Directory Manager
ds-cfg-alternate-bind-dn: cn=Manager
Restart OpenDJ and you will be able to use either one.
May 26, 2022 5:49 PM UTC
I would like to know how to do that too.  We can set the Bind DN to "CN=Manager" during OpenDJ installation, but the login GUI continues to defaults "CN=Directory Manager".
May 26, 2022 8:46 PM UTC
I found this: The default value for the bind DN is for the root DN user, cn=Directory Manager.
https://docs.oracle.com/cd/E19450-01/820-6169/to-start-the-controlpanel.html
We set Bind DN to "CN=Manager", so would it be a step to set the root DN user to "cn=Manager"?
3-Newcomer
May 27, 2022 1:12 PM UTC
I already have "ds-cfg-alternate-bind-dn: cn=Manager" in the config.ldif file and I am able to login as cn=Manager. The issue is that when I launch control panel the login GUI defaults to "cn=Directory Manager" for the Bind DN and I would like it to default to "cn=Manager" so that I don't have to change it each time I launch.
3-Newcomer
May 27, 2022 1:24 PM UTC
That's the whole purpose of this: you don't have to change it each time.
Let it to "cn=Directory Manager". I don't see the point to change it since it's the same account.
