Aug 29, 2023 11:19 PM UTC
Delete or edit Windchill PDMLink Views similar to loadfromfile
I am looking for a workaround to edit and delete views without having to edit them manually through View Administration. This article says it is not possible via loadFromFile, is there some other way?
18-Opal
Aug 30, 2023 1:42 AM UTC
The short answer is yes.
But whereas you have omitted ANY details at all no specifics can be provided.
Here’s a thought, always provide the same information you would ask for if you were asked to solve the problem in question.
Aug 30, 2023 1:37 PM UTC
I have a view in the system that was created through the UI in View administration. I am looking for a way to update that view programmatically, without needing to do it manually in the UI. I looked up the loadFromFile method, but that is only for adding views.
18-Opal
Aug 30, 2023 1:43 PM UTC
Update it to what?
Are you saying you simply want to change the name of the View?
What’s the view name now?
<BR><BR>
