Nov 14, 2024 2:04 PM UTC
Delete stucked executing job in queue
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS20
publish job unable to delete from queue. when tried Queue stuck in stopping state.
    Catalina
    Community Manager
    Nov 14, 2024 2:07 PM UTC
    Hi @GK_10890476
    Thank you for your question!
    I’d like to recommend to bring more details and context to your initial inquiry.
    It also helps to have screenshot(s) to better understand what you are trying to do in your process.
    Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
    Thank you for your participation and please let me know if you need further assistance!
    Best regards,
    Catalina | PTC Community Manager
    Nov 14, 2024 4:03 PM UTC
    Try using the command line utility. You can delete items out of the queue more easily using this than you can through the Windchill UI for queues. See PTC article on how to use it:
    https://www.ptc.com/en/support/article/CS134506
    Catalina
    Community Manager
    Nov 20, 2024 2:19 PM UTC
    Hi @GK_10890476 ,
    If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
    Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
    Nov 21, 2024 5:54 PM UTC
    This is a typical problem with the WVS publish queues as the Windchill queue waits for an external event (the CADworker), and if this communication is missed the job and the queue get stuck.
    Please see https://www.ptc.com/en/support/article/CS37569 for the handling and troubleshooting WVS publishing queues.
    Michael
